Creates an EAPS shared port on the switch.
ports | Specifies the port number of the common link port. |
N/A.
To configure a common link, you must create a shared port on each switch on either end of the common link.
The following command creates a shared port on the EAPS domain.
create eaps shared-port 1:2
This command was first available in ExtremeXOS 11.1.
This command is available on all platforms with the appropriate license. For complete information about software licensing, including how to obtain and upgrade your license and what licenses are appropriate for this feature, see the Switch Engine v33.1.1 Licensing Guide document.
